Led denne svietenie
honza72
Re: Led denne svietenie
Příspěvek od honza72 »
No jo, vždyť to je to s těmi relátky, co jsem navrhoval dávno... Jen jich musí být více, protože se musí odpojit obrysovky přední, zadní, osvětlení RZ a ty tlumené potkávačky...
Ex. Cruze, Kalos, Nexia
frezzi
Příspěvek od frezzi »
Boeing na ktorej 16 strane ? :PP:
Boeing737
Příspěvek od Boeing737 »
Hello,
Your car is very tricky to install an HID system on. The Chevy sonic has the daytime running lights and the headlights in the same bulb. This setup is not compatible with any HID kits. However, you can make HID's work by tapping into the parking lights to power the relay harness. Basically how it works you leave the factory headlight plugs disconnected on both the driver and passenger sides. Instead of connecting the relay harness to the factory headlight plug, you have to connect it to the + and - wires of the parking light bulb. Since the Parking light bulb functions as a turn signal as well, you have to make sure you select only the parking light wire (that does not blink)
With this step you install the HID system like normal with the bulbs and the ballasts. But the relay harness is turned on by the parking light instead of the DRL/headlight. This works well and eliminates problems. The only think to consider is you will not have any daytime running lights. When you turn on your headlights or parking lights, then the HID's will come on. Most customers are ok with this.
frezzi
ak som tomu dobre pochopil tak nejake rele zapojiť namiesto parkovačiek ? ....alebo v tom zymsle ?
Boeing737
Len tam menili H7 za HID
frezzi
myslel som si, len som si nebol istý -P
Boeing737
Dnes som bol v servise v KN.
Riešil som tam inú vec,ako svetlá.Keď som tam už ale bol,tak som sa ešte raz spýtal,či by sa to nedalo vypnúť.
Prvý krát mi povedali,ešte v januári,že sa to nedá. Dnes tam ale prijímací technik nebol a riešil som to s predajcom. Ten hneď išiel za elektrikárom,ktorý mu povedal že sa to DÁ!!!
Vraj musia vyžiadať "len" nejaký kód na vstup do RJ a tam to vypnú! Tak nie je nutné prehrať celý soft a riešiť to on line s GM ako mi tvrdili v NR.
Pri ďalšej návšteve servisu sa na to vraj pozrú,lebo tam budem musieť prísť ohľadom olupovania farby z ovládačov /je to v inej téme/.
Som ale už skeptický,lebo keď príde k lámaniu chleba,tak z toho môže byť zase problém.
Nuž-uvidím,či im GM pošle kód na moje VIN,keď už žiadala Nitra zmenu softu. Možno to bude problém,aby GM zo seba nerobila blázna,že raz povolí a raz nie.Skúsim im navrhnúť,aby udali iný dôvod vstupu do BCM... Keby mi v KN ešte v januári nepovedal že sa to nedá,tak to nemusím riešiť cez celý svet 3 mesiace.
Vtedy stačilo možno to,keby sa technik išiel spýtať elektrikára... nakoniec mi to vypnú za 10 min.tam,kde som začal.
Nechám sa prekvapiť,ale dávam tomu tak max.3-5%
honza72
Dyť jsem Ti povídal, že nejlepším řešením je odškrtnout funkci v SW auta a je to.... Jen třeba najít shodně naladěnou osobu v autorizáku. Mě spíš se.e jiná věc. Až tu Chevy (alias GM) nubude dodávat za pár let, na poměrně moderních autech cca do 5-10let staří, podporu než je sešrotujeme, prostě nebudou přístupové kódy, tak co se spraví v elektrice, asi kulový... -P
Boeing737
Hneď ako si mi napísal,že cez SW,tak som obvolal každý servis v SR a do 200 km od hraníc v zahraničí.
Nikto nič... ja som išiel rovnou cestou.
Ešte ani KN nie je istý.
Boeing737
Naposledy upravil(a) Boeing737 dne úte bře 31, 2015 00:22, celkem upraveno 1 x.
Boeing737
Opäť som na začiatku.
Ani v KN svetlá vypnúť nevedeli :(((((
To je trápení, že? -P
Boeing737
Ok,tak som to už vzdal!
Nebudem mať denné,ale len pozičné :lol: Tie môžu podľa zákona svietiť spolu,lebo intenzita svietenia sa zníži o 50%
Len mám problém,že po 90 sekundách zhasnú. Buď sa zmení napätie,alebo musím zmeniť káblovanie?
Jeden je na kostre,jeden na parkovačkách a jeden /15/ zapaľovanie. Tak je to aj v návode.
Možno v aute sa po štarte zníži prúd,alebo niečo sa odpojí.... aj keď ide kúrenie,stierače,rádio,svetlá aj tak sa to vypne.
Zoberiem to elektrikárovi,len keby náhodou niekto vedel,tak by som to vedel spraviť aj sám,lebo už mám skúsenosti :o)
A jeden drát správně na zapalování nebo jako já v pojistkové stříňce -i :PP:
Boeing737
Ale prečo sa vypnú?
A keď ich miesto parkovačiek zapnem na H7?
Zpět na „Aveo - Elektronika“
